Upgraded Drop Link Kit for those of you with Bilstein Coil Overs
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
hey fellas this one is of interest to those of you with Bilstein Coilover kits on your 997TT... Over the last year or so we've talked to many shops and all of them have seen failures with the provided bilstein drop links. We've been installing similar kits on other AWD cars for over 6 years without one single failure but some point last year Bilstein decided to change the design of their drop links (perhaps due to cost?) and they are now a weak point. The plastic insert eventually pops out and comes apart.
The come apart like so:
![](http://videos.g33kd.net/P1100876.JPG)
![](http://videos.g33kd.net/P1100875.JPG)
You can see Bilstein's older design as used on PSS9 kits from the past. Notice the end itself is a different design and much akin to OEM. With those we never had problems (ever). Funnily enough the PSS10 kits have now also reverted back to the old design again (thankfully).
Here's a picture showing the drop link design of "old" (that used to work and looks like OEM as well) vs the "new" which just isn't up to snuff:
![](http://videos.g33kd.net/P1100878.JPG)
Either way we brought this to RSS' attention (as they had also seen failures like this) and they've made a stronger (and adjustable for those sway bar kits) replacement kit. This kit is now available and I'd suggest checking your front drop links out.
Here's what the folks at RSS made for us (cheers lads):
Here's the orientation of them in case you are wondering (from bilstein's instructions):
![](http://videos.g33kd.net/bilstien_instructions997AWD%20drop%20link.jpg)
For those of you with "noise" in the front area of your suspension go ahead and check to see if the drop links have failed. There's always hope that Bilstein will revert back to the older/OEM-style design that they used to use which never failed (indeed they did this on the PSS10 after enough complaints) but until then here's what you might end up needing:
http://www.sharkwerks.com/products.php?pid=244
Like many others...mine were installed improperly and have since been re-done...
Shouldn't they be ok now?
They are definitely plastic...
Will do...just what I need...more time with the car in the shop!
I can see yours and they do look like the plastic-style old ones
Hey Alex
Yeh, it isn't my PC as I have 3 of them round me right now, and none of them work. Plus my iPhone can't see them either. I guess your image servers are blocking based on my UK IP. I can see most of the pics on your website though.
Anyway, bad news about my decrepit drop-links though. Will get onto my Bilstein fitter and see what he suggests. And yes, they are GMG sways.
From the GMG site in describing my sways:
So I guess if my Bilstein front drop-links die (rear ones are still stock) then I can just put the original Porsche ones back in...
The GMG WC Sport Sway bar kit is designed to work with the factory drop links and does not require the use of a rod end style drop link to clear the front axles which ensures that you dont have unwanted noise and popping due to the use of in-expensive rod ends used by most competitors.
Hey Alex
Unfortunately the factory ones won't work.. the ends will and you could custom make some like that;(
Adjustable ones are apparently a nightmare from shaking loose after a few thousand miles of bumpy road driving (like we have here in the UK). So I would never fit anything other than Bilstein, stock Turbo or GT3 spec drop links myself.
