997 Turbo Forum 2005-2012
Project 997TT adds JIC Cross Exhaust System - Big Gains!
Old 07-23-2008, 12:29 PM
evolvedaz
Former Vendor
evolvedaz's Avatar
Default Project 997TT adds JIC Cross Exhaust System - Big Gains!
Our next stage on our Project Porsche 997TT was to put on an exhaust and free up the exhaust flow. Turbo cars biggest restriction is always the intake and exhaust system. Once these are opened up, the stock turbo performance will be maximized. A turbo car really does not need back pressure, but in that case, if you had straight pipes, it would be LOUD. JIC Cross of Japan developed this exhaust system to produce strong horsepower, but also have a great sound without droning in the cabin. Part of their exhaust, the JIC system can be ordered in full titanium or as seen here in all stainless steel. The exhaust uses 200cell catalytic converters so there are no issues with check engine lights. The quad tips add a much improved tuner look and are integrated into the piping for improve exhaust flow.
We tested the exhaust in both sport and non sport mode to show the results of how the system plays out. Sound clip will come later. Driving on the roads in the 2400-2800 RPM range, the exhaust does not have that "drone" that other systems have. The exhaust does roar when you step into it.
The car baseline run without sport was 387awhp and 411 tq. Without sport mode on and just the exhaust installed, the car made 412awhp and 417 tq. With sport mode on and the exhaust, the car put down 425awhp and 440 tq on our Mustang Dyno. The numbers on all these tests could be alot hire due to one issue, heat... The average room temperature was about 105F degrees. Cooler temps, better air flow, and fans placed DIRECTLY on the intercoolers, we would probably see an increase of around 15hp.
Next up is our Softronic ECU upgrade which will hopefully bring us closer to the 500awhp mark!
Check out all the Porsche 997TT parts including exhausts and suspension available here - http://www.vividracing.com/catalog/i...=38&class_8=38
View the rest of the install and project car photos here - http://www.vividracing.com/forums/ga...ages.php?c=342
Old 07-23-2008, 01:20 PM
TT Surgeon
TT Surgeon's Avatar
nice dan
Old 07-23-2008, 02:30 PM
InTheAir
InTheAir's Avatar
Dan -
Can you confirm the above numbers? The numbers look confusing:
Run 1 = 412hp / 417ft lbs
- "Exhaust with Sport ON"
Run 2 (3 minutes later) = 387hp / 411 ft lbs
- "Baseline wit Sport OFF"
- Can the baseline be after the first run?
- Shouldn't the baseline have been with the Sport ON if it will be compared to other runs with Sport ON?
Run 3 (next day) = 425hp / 440 ft lbs
I'm toying with the idea of doing a similar upgrade, but as I look at this data it seems a bit confusing. What am I missing?
Quick Reply: Project 997TT adds JIC Cross Exhaust System - Big Gains!
