997 Turbo Forum 2005-2012
Overboost question
Old Nov 7, 2007 | 01:03 AM
2thfixr's Avatar
2thfixr
Default Overboost question
How exactly does overboost work? Pressing sport chrono gives you 10 seconds of overboost but does it reset everytime you stop so you can have multiple overboost episodes or is it a one time boost per activation of sport chrono mode? Does the counter start as soon as the turbos kick in or is it only with WOT at max boost?
Old Nov 7, 2007 | 01:30 AM
atomic80's Avatar
atomic80
It resets every time you lift off the gas. Also, when you see the little uparrow the overboost is active.
Old Nov 7, 2007 | 04:03 AM
2thfixr's Avatar
2thfixr
Uparrow? Where should I look for this?
Old Nov 7, 2007 | 04:17 AM
2thfixr's Avatar
2thfixr
Did a little search and answered my question. Does it matter whether I am in the PSI or Bar mode?
Old Nov 7, 2007 | 06:58 AM
atomic80's Avatar
atomic80
No, doesn't matter although it'd be easier to notice the "overboost" mode being in play when you're in the BAR mode because it goes up to 1.2 bars then. Normal boost maxes out at 1.0 bar.
