intercooler & intake
#31
Originally Posted by TurboTim
The dyno test is not the best method.
Edit: I have re-read a few times, you are saying the dyno method is by no means the best method right ?
It was highlighting Jean's post which confused me
Yes.Exactly.The dyno is not the best method but if you see gains on the dyno then you definitely have something there.
#32
LAT cruising at 80 odd mph is barely using any boost, the Secan will typically hold to virtually ambient at this sort of cruise....Give it some beans and report back
I would if it were not July in Italy and more traffic than roads. The point is even in a no boost condition I am not holding ambient. The temperature is the same at 100 - 110 mph. about 10 Deg C abovae ambient.
What I was hoping for is ambient at no load and close to ambient at full load.
Tim, what are your thoughts?
