laser-jam hookup, need ideas for wire path
Originally Posted by turbojohn
Allegretto.........any luck finding best route for laser wires from front of tt to inside cabin. Hopefully will not have to drill hole. Called K40, you are correct, only their radar is remote, the laser is not
For your information the K40 has never worked in any independent testing and I have tested the K40 Calibre ($2,500 + Bluetooth) and it failed in protecting against laser worse then blinder which is also a very bad performer also against police laser.
Well if you want my honest opinion...I will say the Laser Pro Park, due to many reasons.
1). small very concealable jammer head
2). Can be very stealthy if placed in the proper locations and also protect the front and rear of your car's.
3). Very powerful..that is why 1 head is just generally needed but 2 will give you the "Ultimate" JTG performance if you want. I only have 1 head up front and I have no problem doing full jam to gun.
4). Doesnt give the Cop jammer codes like the less powerful LED laser jammers.
Originally Posted by allegretto
Boo, he's talking a laser jammer. I assume the active type, not a passive one as comes with the K40.
I have the Blinder TJohn. My wrench did a very cool job. In Illinois they are illegal so he installed it with the hiders that lift it up. He cut into the bumper and it is a superclean install. If you look all over you still wont find it, it goes into the bumper flush.
I'll take some pics and put up a post. I'll call him and ask him how he routed it if you like...
Porsche 997 has holes on the front right (where passes an other cable) and fron left, (drivers side)where is empty and you can make a hole there and pass your wire to the front bumper... from there you continue and pass straight to the drivers side in cabin..
Originally Posted by Vincy
What is a Blinder TJohn? I can't find it with google.
http://www.radarbusters.com/products...er/default.asp
