997 Turbo Forum 2005-2012
Recall!!!!!!!!!!!!!!!!!
Old 11-28-2006 | 12:24 AM
cat3010's Avatar
cat3010
2nd Gear
Default Recall!!!!!!!!!!!!!!!!!
Had my 911 TT one month and received a recall letter stating "due to an incorrectly programmed spot welding machine, the welding spots at the left rear wheelhouse were not performed correctly." They seem to downplay it a little. Should I be worried and how much of the car do they have to take apart to reweld it properly.
Old 11-28-2006 | 12:35 AM
PorschePhD's Avatar
PorschePhD
Rennlist Lifetime Member
Weld issue The car will creak. I welded mine up. Here is the thread.
Old 11-28-2006 | 12:39 AM
atomic80's Avatar
atomic80
When were both of your cars built?
Old 11-28-2006 | 12:43 AM
PorschePhD's Avatar
PorschePhD
Old 11-28-2006 | 01:08 AM
turbojohn's Avatar
turbojohn
Default Let us know final outcome on weld problem
Probably something simple. Most likely just removing a rear tire will show the required area to spot weld(hopefully). But strange, such a problem, for quality control that is bragged by Porsche and shown by JD Powers data. Let us know how simple it was (or complicated). And if it took most of the day like most warranty issues do. As I remember your tt was built back in September '07...correct?? Hopefully that weld-bug has been worked out with future tts. And too, your turbo had some Quality control problems prior to delivery also??. Hope your problems are not a sign of things to come with Porsche quality.
Quick Reply: Recall!!!!!!!!!!!!!!!!!
