LSD or no LSD, that is the question....?
Originally Posted by C4S Surgeon
LSD is not available with a tip.
Re tip vs manual on track: The tip is faster if you are a novice, the manual faster if you are an expert. Mastiff has gained stature thru the elegance of his answer. Wealth was the reward of his genius. AS
LSD and 4WD and tip
I don't understand how the LSD works with 4WD? If on ice will one out of 4 tires spin? I thought the 4WD system shifter the power to the wheels with traction. Can someone explain this system? Thanks
I give up: what the heck is the "LSD" option. Is it the the rear axle differential lock? If so,
I assume this option would primarily be an advantage tracking the car, and not for regular
street driving?
Sammy
street driving?
Sammy
Originally Posted by dsts6
Also, quick question, is tip faster then manual on a track or just 0-60.
thankyou
dsts6
thankyou
dsts6
I have to agree as well. LSD is an awesome option. Getting the power down when the car is heavily loaded in a corner has never been better.
Thumbs up...
Now if I can just get the trails to stop when I waive my hand in front of my face, I'll be happy. Is that purple haze?
Thumbs up...
With the 4-wheel drive, there is an electronic limited slip built in, that is, if the rears slip, the fronts take over. With the mechanical LSD, the rears won't slip...so the car's power is still more in the rear than being delivered to the front tires. I think it a good thing especially in wet weather. Well worth the $950 price. Porsche tells me, the LSD will not interfer with PASM, only enhances it. Also enchances only ASR (antislip regulation), ABD (automatic brake differential) and PTM(porsche traction management) systems that are standard in the new 911turbo.
I speced mine in Friday; lsd, sc, adaptives, thick wheel, crests, heat, etc all for 128k!
Can't wait.
Can't wait.
