Expected displayed boost pressure?
2011 turbo, I’m wondering what are the stock boost numbers you all normally see, and what are the normal over boost numbers you see as well.
If I lock it in 6th at 2.5k rpm and put the pedal to the floor, I see 15psi and ⬆️ on the LCD. I understand stock non-overboost is 14psi; I thought for overboost (the arrow), I should expect to see 17-18. Is that right?
I’ve done this test a few times - lock it in 6th, start at 2.5k rpm, pedal to the floor, and I see 15 psi with the arrow. I THINK it should be reading a bit higher though.
any input appreciated for the general value I should see here when testing this way. Thanks
