997 Turbo Forum 2005-2012
Check engine light
Old Oct 13, 2024 | 03:35 PM
Guttersnipe's Avatar
Guttersnipe
Default Check engine light
Hi guys! Have you guys dealt with a lean at idle bank 2 code before? What could it possibly be? Most likely a vacuum leak after the maf?
Old Oct 14, 2024 | 12:11 PM
lliejk's Avatar
lliejk
Sounds like a good place to start. You also might want to try cleaning the MAF's.
Ed
Old Oct 15, 2024 | 01:18 AM
C2-996's Avatar
C2-996
Also, possibly check to make sure your fuel pressure regulator line didn’t pop off. Here’s a good thread on that below. Also can cause a lean condition.
https://rennlist.com/forums/997-turb...fpr-lines.html
Old Oct 24, 2024 | 07:11 PM
Kaili's Avatar
Kaili
6th Gear
It is recommended to read the fault code via an OBD-II diagnostic device and further troubleshoot it in conjunction with engine data streams (such as fuel correction values, oxygen sensor readings, MAF sensor data, etc)
