Engine out service costs.
Hello! So I found coolant leaking from the front of the motor, a good amount was pooling under the car. Looked like the plastic elbows were getting old and about to give out. It definitely going to be an engine out service, P3 Autokräfte a local Porsche shop has quoted nearly 14k for Pinning the Cam gears, welding on the coolant pipes and replacing various other hoses. It is stated that this estimate may change because they need to look at the labor over lap.
I've got a couple other quotes but they have not seen the car however I was pretty through with the details of what needed to be done. Their pricing about 50% less than that quote.
What are some prices you've seen for this type of work? Any help with be so appreciated!
