E Ram Pics
#31
More of a hassle because there's less room between the 2 spoilers to work with. Installed my 4 inch E-Ram super fast today. Pics to come.
The following 2 users liked this post by TV997S2:
babylonboots (07-28-2023),
RennKit-Dave (07-28-2023)
#32
would love to see stock, 2 inch and 4 inch pics if you have them for comparison.
having a hard time deciding which ones to go with.
#33
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
#34
lots of pics here: https://rennkit.com/testimonials/
yeah I’ve been through your website and other pictures online…. But never see any before and after pictures or comparisons of side by side between the heights from the same angle, all the pics are random angles and hard to tell for comparison.
looks like a great product and will be ordering one end of next week just not sure which one!
what I’ll end up doing is just going out to the car with a tape measure and try to see where they’d sit!
RennKit-Dave (08-24-2023)
#35
The 2" is a bit of a PITA because as was said above, because the 2" lift is shorter, there is not enough room to work the pin wrench around in the same fashion that you would have if the rams sat higher. As a result you need to do some additional removal. I ended up with the wing sitting about 1/4" higher off the bottom wing as a result when the spoiler is retracted. I am pretty sure if I disassembled I could adjust, but to be honest, don't really want to and it looks completely fine. If you didn't own the car before you wouldn't have any idea, it looks completely stock and normal.
I personally don't care for the 4". I think it looks too tall in the photos. I think the 3" is the sweet spot and the extra $100 will save you some labor time so it's worth it.
#36
I would go with the 3" if I had to do it again.
Needsdecaf (07-31-2023)
#37
I think the 3" eRam works well with the overall proportions. I originally installed the 4", but swapped to the 3" after a couple of months. Dave is very helpful with installation guidance (if needed) and support.
This is the 3" eRam kit...
The following 4 users liked this post by Carlos4S:
DaveCarrera4 (08-04-2023),
Elliotw44 (08-06-2023),
Needsdecaf (08-04-2023),
The following 2 users liked this post by Kayaknfly:
Needsdecaf (08-24-2023),
#39
Really like the look of the 3" kit, thanks for sharing. Prior owner replaced the hydraulics on an extended warranty within last few years so think I'll be good for awhile but when it happens again I'll definitely go this route. Nice visual improvement and love that it is a relatively simple DIY.
#41
Installed mine yesterday. 3 inch super fast kit with dust boots.
before (stock height) and after shown.
So far liking them a lot. Install pretty straight forward.
thanks Rennkit!
also installed their btr-3 Bluetooth module. Works great! And some new stereo *****.
Old sticky…
New
Btr being installed.
Stock
Stock
Stock
3 inch
3 inch
3 inch stowed (still sits flush)
thanks Rennkit!
Old sticky…
New
Stock
Stock
Stock
3 inch
3 inch
EVOMMM (08-24-2023),
