Is this normal boost build up for a stock car?
People always mention 1 and 1.2 bar in over boost but is that peak? Does it peak and drop off or does it hold that boost through the RPM range.
1.1-1.2 with overboost. Normal is 1bar normal mode. Pressure test for leaks and check the IC end tanks. If VNT's are starting to seize up then will get funky boost readings.
