Anyone know this plug?
Hi all. As I was in the process of removing parts to access the fuel injectors, I noticed a plug just dangling. It appears to be the same type of plug used for the fuel injectors, but those are all fully intact. As I trace the plug wire, it looks to be joined or threaded with another plug. I’ve taken pictures of both the loose plug and the other plug with which it seems to be related. Any suggestions would be a huge help! Thanks!
Loose plug
The other plug threaded along with the loose plug.
Loose plug
Just basing it on color of the wires it's "throttle position sensor plug"
Thank you, that looks to be the same plug! Of course it’s all the way in the back of the engine… What does the switchover valve do exactly? Would this have an impact on the speed density tune I’m currently running? Thanks!
