When I bought my car 2 years ago I noticed that there was a wear mark on the black trim of the passenger side rear window where the door glass touches it when the door is closed.
Wear mark at top of black edge of rear window
Looking at the rear window it appears that it is not parallel to the edge of the door glass and that is why the window hits it when being shut. I guessing that the rear window needs to be adjusted back so it doesn't go past parallel to the door glass.
Does anyone know if this is a mechanical adjustment inside the quarter or rather programmed through the window switch to adjust the final position at full up?
