997 Turbo Forum 2005-2012
Post 02 sensors rich code setting
Old Sep 17, 2021 | 11:18 AM
Fredseuro's Avatar
Fredseuro
5th Gear
Default Post 02 sensors rich code setting
Have a 2007 (WP0AD29907S784703) other shop threw new post cat 02 sensors and codes comes back.
Have scanned with our piwis and iscan live values. Nothing is out of range @ this time.
code 2099/2097 indicating post sensors rich. Smoke testing exhaust and intake, nothing. Could this be a programming
issue or possible CATS?
Freeze frame : Close loop control
Engine temp 182
Short trim Bank 1 -.078
Long trim Bank 2 5.47
Short trim Bank 2 -2.34
Long trim Bank 2 7.03
Engine RPM 2796.50
Veh speed 65 mphs
Old Sep 17, 2021 | 12:10 PM
lliejk's Avatar
lliejk
Anything change recently before getting the codes?
Ed
Old Sep 17, 2021 | 01:02 PM
Fredseuro's Avatar
Fredseuro
5th Gear
New customer to us. Vehicle runs very good. Looks to be maintained properly.
Post cat 02 codes can be tricky. Porsche is one of a few manufacturers that utilizes the rear 02 to help
set fuel trim where most only use rear to monitor cat efficiency. You would think a rich setting code for both rear
02 would also set front. I'm inclined to think possible software or programming could be needed. I'm going into
Porsche site to check TSB
