997 Turbo Forum 2005-2012
Which Battery? H7 or H8
Old 10-12-2020 | 08:15 PM
Sobrut911's Avatar
Sobrut911
Yeah it’s heavy, especially when you have two bulging discs. The only way I could do it without blowing out my back was to undo the cables, vent tube and retaining clip and then stand in the frunk and lift the battery out and place it in the frunk and then get out and then lift it out.
Old 10-14-2020 | 03:40 AM
Jeff Jones's Avatar
Jeff Jones
I just put in the H6 40ah Antigravity battery in my TTS. Super easy swap other than lifting the heavy lead acid battery out. I also hopped in the frunk to make it easier. With the H6 I had to slide the battery clamp one spot over but it fit perfectly after that.
I was on the fence about spending the money but I like how light it is, I like the remote jump capability and if it lasts 3x longer as advertised, it should be close to a wash.
Antigravity (10-14-2020)
Old 10-14-2020 | 04:03 AM
Hula's Avatar
Hula
Originally Posted by Sobrut911
The H7 is length 12.437;width 6.937;height 7.5 inches. The H8 is length 13.937 inches; width 6.937; height 7.5. Has anyone put in an H8 battery and is it an exact fit ?
I installed an H8 Bosch will little issues. I wanted the extra amps for cold weather cranking. The larger H8 battery is an option in some markets hence the extra holes in the tray. The clamp has to be moved one position and a nut will be needed for the hold down bolt.
For a "frunk situation" I keep a Li-ion jump starter in the cabin. The battery weighs about 2 pounds and slides under the driver seat.
Old 10-14-2020 | 07:50 AM
nzskater's Avatar
nzskater
Highly recommend a CTEK charger, and the extension cable - connect it to the battery terminals permanently and have it sitting under the little removable cover in the windshield cowl on the left hand side of the car. The pig tail fits perfectly, and you’ll never be at risk of being stuck with a flat battery.
Jeff Jones (10-14-2020)
Old 10-14-2020 | 02:21 PM
gary1101's Avatar
gary1101
Kind of like this.
The following 4 users liked this post by gary1101:
Antigravity (10-15-2020), Jeff Jones (10-14-2020), Needsdecaf (10-14-2020), nzskater (10-14-2020)
Old 10-14-2020 | 04:29 PM
nzskater's Avatar
nzskater
Yep, exactly that!
Quick Reply: Which Battery? H7 or H8
