Will Sway Bars help me on track days?
I have a 2011 TTS stock but for a sharkwerks muffler delete exhaust. I'm not a huge track guy, maybe a couple times a year doing a High Performance Drive day. I was thinking about adding sway bars to help on the turns as a not crazily expensive upgrade, but I don't know how effective they are alone. I know i can put in new suspension, coil overs etc, but that's not what i'm after at this time. So, will sway bars alone positively impact my handling, and if so, any recommendations?
Thank you
Thank you
Yes, they will. I put the GT2RS rear sway on my car, set to medium, to remove some of the under steer character and make turn in a bit easier. It makes the car feel better on road and track.
It’s a cheap mod and only takes 30 minutes to install at home. Highly recommended.
usrodeo4 (09-30-2020)
It’s the OEM rear sway bar from the GT2/GT3RS. There’s more info and a link to the product on Suncoast below. You’ll need new bushings (that they sell) as the bar is a bit thicker than the OEM turbo bar.
https://rennlist.com/forums/rennlist...d.php?t=969392
For an affordable and proven upgrade just add a DSC controller and a GT2 swaybar/bushings. This will improve overall handling and improve ride without sacraficing NVH....all for around $1500. For a more track focused car consider lighter weight wheels and stickier 18" track tires.
My experience is that a GT2 bar set on softest position in combo with DSC yields better handling than a stock controller and GT2 bar in the middle position....better grip, less rear rotation at the limit and nice pitch control.
Rig.Stunts (09-30-2020)
the OEM GT2 sway bar will not fit a PDK car.. it will fit the manual (I have one on mine and am very happy with the outcome).
You could check with TPC racing as I believe they have a sway bar that will work on the PDK cars.
I have to be honest.... I hardly get these tires up to temp and I drive them in the rain. Lets just say it makes it much more interesting at mere country road speeds! But they sure look cool! I think it will be 4s the next time... unless I make the mistake and find a new GT2 sitting on the dealer floor and see what is coming on that! I'm that sucker we all know for the laser cut Michelin nomenclature on the sidewall.
cyclrder (09-30-2020)
Thank you
Thank you
Just enjoy the car as is.
Craig
The rear sway bar and a much more aggressive alignment absolutely makes a difference for non track driving (I don’t track my car and can’t speak to that) but I certainly can pull the performance out of the car on the back roads of Ct.... but for the best return on money.. the DSC modules is the first purchase.
PowderJunkie (10-05-2020)
