springs
#31
So most of you are changing out the springs, but not the shocks? Are you able to do this because PSM compensates for the shorter travel without blowing out the shocks? How are your bump stops?
#32
Shorter springs that are progressive retain some/most of the ride comfort but aren’t the best for handling. Again, aren’t great on struts but isn’t all that bad.
These manufacturers (most) take into the consideration that the struts you are using are OEM.
#33
B8 Damptronic + Eibach springs = Perfect
