Key intermittent
On about every 1 out of 10-15 starts, I don't get a response from the car when inserting the key. Have to remove and usually works on 2nd attempt (one time 4 attempts). I'm thinking ignition switch, as the car has 70K miles and is behaving like my 986 S at about 65K. Replacing the ignition switch did the trick at that time.
Thoughts? TIA
Thoughts? TIA
Have you tried both keys? Could be a key fob battery...
It certainly sounds like the switch, although it could be the starter or the wiring to the starter. Do all the dash lights come on and everything else look normal, just no crank, or do the electronics not respond to the key at all?
Ed
Ed
Basic Sponsor
Wonder if it could be the "pill" reader? Not sure where it is, but the key fob pill needs to "talk" to the receiver in the car before anything will happen.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
