997 Turbo Forum 2005-2012
Rear spoiler programmed
Old Oct 13, 2018 | 04:45 AM
John Shotter's Avatar
John Shotter
5th Gear
Default Rear spoiler programmed
Hi all my 997 just had a new rear control modul everything works apart from the spoiler does this need programmed do you know and is it easy to do?
Old Oct 14, 2018 | 04:36 AM
DaveCarrera4's Avatar
DaveCarrera4
What do you mean by "rear control modul"? There is no programming, unless someone shut off spoiler operation with a PIWIS or Durametric.
Old Oct 14, 2018 | 04:41 AM
John Shotter
5th Gear
yes I replaced the rear control module however since then the spoiler won’t go up of down? You can make it go up and down when plugged into durametric but not front the button? The button has also been tested?
Old Oct 14, 2018 | 07:51 PM
ledd4u's Avatar
ledd4u
If you replaced the module, then it needs to be coded. If you had a durametric suite, you could have copied your modules configuration. I saved all of my modules for future repair. Some you can't code, like the cluster module.
Old Oct 21, 2018 | 03:10 PM
MK19's Avatar
MK19
Default Rear "Spoiler Control Failure" message - Trouble Shoot?
It will go up but not down automatically (periodically). Sometimes the manual switch works, other times not.
It looked like it was the upper limit switch that wasn't registering. I broke the switch getting it out and so couldn't confirm this guess. I replaced the switch ($45+) and confirmed both switches operational. No effect on the fault.
Is there a way to trouble shoot the control module?
I have both PIWIS and Durametric.
Thanks in advance for any help here.
MK19
Old Oct 21, 2018 | 03:19 PM
nzskater's Avatar
nzskater
If you send the spoiler Up and Down commands via Durametric does it work?
You code the automatic spoiler feature in the Gateway section I think. Perhaps check there
