Code P2004 !! HELP !!
Hello members!
After install an aftermarket exhaust system. 200 cell Cats
a P2004 code showed up. " NO CEL " but showing from a diagnostics (OBD) system.
What should I do? Anything I should be worry about?
After searching around, someone mentioned O2 sensor extenders
would that clear the Code ?
You either jacked up (damaged) your O2 sensor during install, or need the bung extenders. Only other thing that would cause that would likely be a bad Cat, so that is likely not your issue if you just installed?
DC
DC
