997 Turbo Forum 2005-2012
997.2 turbo rocker panel repair
Old 12-04-2017 | 07:49 PM
6S219's Avatar
6S219
Default 997.2 turbo rocker panel repair
At some point in time I must've run over something causing it to fly up under the car hitting the driver side rocker panel and breaking the clip that holds it in place flush with the body. I removed the rocker panel and mocked up a piece of plastic to act as a retainer clip to keep the panel flush with the body. I used my plastic welding gun and was able to get the piece attached to the rocker panel. I am bedded a piece of wire into the plastic for rigidity. Although it may not "look pretty" the repair work out very well!
____
Old 12-05-2017 | 05:05 PM
o7silverturbo's Avatar
o7silverturbo
Nice! I dont know if I could live with know that yellow piece was on my rocker panel tho lol
Old 12-07-2017 | 02:28 AM
6S219's Avatar
6S219
It is hideous however the for a plastic weld to be effective the bonding material needs to be comprised of the same properties as the piece being repaired. In this case I only had yellow. This is a temporary fix until I decide if I am going to replace with OEM rocker panels or upgrade to the GT2 rocker panels. I'm leaning towards staying OEM.
Old 12-16-2017 | 06:37 PM
IndyM's Avatar
IndyM
Totally off topic... but what wheels do you have?
Old 01-01-2018 | 04:22 PM
6S219's Avatar
6S219
sorry for the delay. I have AG Ruger Mesh wheels.
Quick Reply: 997.2 turbo rocker panel repair
