wishbones 99634134108 and 99733105303 is there difference ?
Hi to all, I were looking for rear lower wishbones for 997 Turbo 2008, looking through ebay noticed some sellers offer 99634134108 like it should fit to 997 3.6 Turbo, and some blame it will not fit. I wonder is there any difference in those suspension arms in Turbo version? Opinions on aftermarket producers? Thanks to all repliers...
I went through this with the trailing arms. As long as you do not mix part numbers on the same car, you are OK. The 996 and 997 part numbers have slight differences in the bushing area where the trailing arm attaches, and thus there are 2 kinds of trailing arms.
So if you need just ONE control arm, you MUST use the same series as the other side of the car. If you need both, you can use either the 996 or 997 part number.
Aftermarket ones are better....cut right to the GT3 control arms with adjustable bushing. That is what I did.
