anti gravity lithium battery RS20.
I'm speaking from experience running a 36ah LiFePo battery in daily driven cars (in about 5 different cars now) with smaller engines and nothing that runs when you turn the car off. I wouldn't trust what I run in my GT3 without more capacity.
My comment was specific to the inexpensive Shorai alternatives. Please read more carefully.
Also, the OEM lithium battery is Lithium Ion and its nominal output is not directly comparable to lithium iron phosphate or regular agm batteries.
here's the issue, a lot of makers of Li batteries advertise "lead acid equivalent" not REAL capacity.
So there is a reason the Braille are more expensive, they have higher real capacity.
Example:
This is a 25AH battery, 'equivalent' to a 75AH lead acid battery
https://www.braillebattery.com/index...atteries/i48cx
The VF VPR-P6 is a 31AH equivalent which is about 10AH actual
http://www.voltphreaks.com/linked/Vo...sPriceList.pdf
The Anti Gravity Battery is a 20AH EQUIVALENT which is about an 7AH actual
https://shop.antigravitybatteries.co...omotive/rs-20/
Example:
now this makes complete sense.
I was always wonder about how a higher capacity battery do be so cheap. So the 18Ah from porsche motorsport must be nominal and not PB eq. , it can last 2 weeks while parked up without CTEK charging.
and indeed the RS-20 is a startup battery only.
Remember to LOCK your car when parking it for a while. After a week car goes into sleep mode. Mine can sit for well over a month - 6 weeks w/o an issue with a LION battery in it (Braille).
I live in SoCal, and have had a Braille GU1R for 2 months - use it as a daily drive - no issues what so ever - lots of radio use/nighttime driving.
7 pounds weight - around $500 39 PbAcid Eq amp hours/13 AH.
That was a cheap way to save about 40+ pounds.
https://www.braillebattery.com/index...batteries/gu1r
Example:
Example:
I was just reading what was on the tin
Thanks for the citation, I'd guess the writing on the battery paints a more accurate picture since I still think you'd have to work hard to make a Li-Ion battery that heavy for that little energy. (shouldn't be 10 pounds if it's only 20 Ah Pb Eq)
BTW: Any norcal track plans?
I've become a huge fan of Voltphreaks LiFePo batteries. They aren't cheap initially, but after numerous failures with other brands of Lithium batteries I think they may actually be cheaper in the long run. They have circuitry and logic built in to protect the battery that seems to be effective. I've been running a Voltphreaks VPH 900 LiFePo in my street driven GT2 for about four years now with zero problems. I've also put them in our Formula Atlantic race cars after experiencing failures with Ballistic, Braille, Shorai, and one other brand I don't recall. We've experienced zero failures with the VoltPhreaks in the race cars as well. Thirdly, I replaced a failed Odyssey PC925 in my Caterham with a VPH900, also zero problems. It's become my go-to lightweight battery.
I've also experienced many failures with Ballistic and Shorai in motorcycles and basically don't use them anymore.
I know this sounds like a sales pitch, but it's not. I have no affiliation with VoltPhreaks other than buying a lot of their batteries. I'm just posting this in hope that someone else finds it useful.
