BBi Autosport Black Friday Sale on Porsche 997 GT3/RS Exhaust, Roll Bar, Suspension
Basic Sponsor
Attachment 1358175
This year has been great to us and Thanksgiving is great time to show appreciation for the love and support from our customers and friends. We are running a special Black Friday Sale promotion for on our entire BBi Autosport catalog, along with selected products from our partners. Here are the BBi Porsche 997 GT3/GT3RS upgrades that will be on sale:
BBi Autosport StreetCup Porsche 997 GT3 Roll Bar
![](https://c2.staticflickr.com/8/7653/16382546854_70f34274b2_h.jpg)
![](https://c2.staticflickr.com/8/7623/17004957125_bffd4c0f82_h.jpg)
Features
BBi Autosport Porsche 997 GT3 / GT3RS StreetCup Exhaust Bypass
![](https://farm9.staticflickr.com/8599/16457283367_3a19185eda_h.jpg)
Key Features
BBi Autosport Porsche 997 GT3 StreetCup Suspension Components
BBi Street Cup Suspension Components Typically Share The Following Features:
BBi Autosport Front & Rear Lower Billet Control Arm Kit
![](https://farm9.staticflickr.com/8654/16663204341_71cf0fbbfd_h.jpg)
![](https://farm9.staticflickr.com/8602/16457964687_2d960ac66c_h.jpg)
(shown with optional camber and litronic shims)
BBi Autosport Front Bump Steer Kit
![](https://farm9.staticflickr.com/8680/16532471130_fe619ddc60_h.jpg)
BBi Autosport Rear Adjustable Toe
![](https://farm9.staticflickr.com/8675/16702789656_64a3cb486c_h.jpg)
BBi Autosport Front & Rear Thrust Arm
![](https://farm9.staticflickr.com/8594/16512680580_5d823c886d_h.jpg)
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
![](https://farm9.staticflickr.com/8584/16037662063_46dcf21b3a_h.jpg)
BBi Autosport Rear Upper Control Arm Kit
![](https://farm9.staticflickr.com/8571/16104616624_13fa5fd5a8_h.jpg)
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to front seatbelt mounts and rear strut towers
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
- Designed to work with stock or any aftermarket seats on the market
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other optional colors available
- Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3
- Compatible with factory Bose subwoofer
- Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Key Features
- Delivers deep aggressive exhaust sound
- Significant weight reduction of 40 pounds
- 304 stainless steel aerospace tubing
- Meticulously TIG welded
- Brushed stainless finish
- Stainless hardware and clamps
- 100% emissions legal
- Will not void warranty
- Factory secondary mufflers and catalytic converters are all retained
- 50 state emission compliant
- Direct bolt on replacement
- Compatible with 997 GT3 and 997 GT3RS models
- Made in USA
- Hard tested on the street and track
- Provides additional adjustment range
- Helps maintain proper suspension geometry
- Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
- Eliminates factory rubber bushings for improved suspension feedback
- Direct bolt-On replacement and requires no modification to the vehicle
- Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
- Precision Teflon lined spherical rod ends for smooth operation and long life
- Discrete black anodized finish for increased corrosion resistance
- Made in USA
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup arms
- Allows proper camber adjustment 996 & 997 Models
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
- A must have for all track and race enthusiast
- Each kit includes pair of 2 arms
- Fits both front and rear axles
- Part Number BBILOWRCNTRL9697
- Helps eliminate bump steer by maintaining proper front end suspension Geometry
- Utilizes misalignment rod ends of the arm to provide maximum articulation
- Highly recommended for vehicles that have been lowered
- Each kit includes pair of 2 Links
- Part Number BBIBUMP9697FRONT
- Provides additional rear toe adjustment
- OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Part Number BBITOE9697REAR
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Part Number BBITHRUST9697
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
- Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
- Complete set of 4 (2 front & 2 rear)
- Part Number BBITHRUSTBUSH9697
- Link the rear wheel carrier to the sub-frame.
- Allow adjustment of track width and kinematic toe.
- Complete set of 4
- Part Number BBIDOGBONE9697
![](https://rennlist.com/forums/signaturepics/sigpic165623_1.gif)
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
Thank you everyone for your overwhelming interest in our products. We have received many calls, emails, and private messages over the weekend and we are working hard to reply as quickly as we can. Just a friendly reminder, our BBi Black Friday & Cyber Monday sale will end today. All inquiries received before 11:59pm Pacific Standard Time today will be quoted with the sale price. For all questions and inquiries, please email us directly at Sales@BBiAutosport.com.
- Jerry@BBiAutosport.com
