AP rotor/Ferodo pads
Clark from Apex is selling the AP rotors and Ferodo pads. Better price point than PFC and Girodisc combo. Some of the 991 GT3 owners are running the combo and like it. Any 7.1/7.2 GT3 drivers using this combo? I currently use 380 Giro fronts and OEM turbo rear PCCB conversion with PFC08's and Nitto NT01's. Any feedback would be appreciated.
I ran both AP and PFC discs on my 7.1RS. Both are great. The slightly thinner PFC "race disc" face does shift bias ever so slightly rearward, as you use a smaller size pad (than stock), but you really have to be in tune with the car to feel it. AP rotors allow for more pad options, via stock pad shape.
If you run PFC, stick with the 34mm thick "race" disc, instead of the 32mm disc. Clarke sells them both, and the cost is pretty much the same. I preferred the 34mm PFC disc, I'd rather change pads more often than rotors.
Also, I ran .2 GT3/RS stock rear rotors, they are made with same Cup disc technology, and I never had to replace them in 4 years of track work (and that's 20+ days/year at quick pace)....with rear brake ducts, and Nitto tires. Ask those who know and they will tell you those discs are a complete world of difference from the stock turbo rears. The initial cost is less than a 2-piece setup, and the savings was worth it to me, since they don't need to be replaced nearly as often. So it's a toss-up, between stock .2 and 2-piece aftermarket, IMO. Both work great, with cooling ducts.
All that said, AP/Essex is coming out with a new brake package for the 987, and that's what I'll likely try if I can't get the stock package to work with all the cooling I've thrown at it.
I would personally try AP front rotors, and whatever on rear except turbo. But definitely add the cooling. I thought AP handled heat a little better than PFC.
Former Vendor
We use Brembo on the cars which I engineer so I would strongly consider that as well. There are multiple options for the 997 GT3 and Cayman.
Depending on the setup and which tracks you go to, you can get your 987 Cayman to have have good brake performance and life with upgraded pads / fluid. And its important to manage your cooling as well to get max life out of the brakes. As an example: on tracks with long straights and hard braking, overcooling the brakes (on the straight) will result in shorter disc life if you aren't checking temps. There is no magic bullet to brakes so you need to tune the brakes to suit your needs.
If you are consistently seeing very high temps (check using rotor heat paint), a brake upgrade will probably help.
The PFC 32 mm disc is thinner to allow for a thicker 19 mm pad. The 34 mm disc gets more life due it being thicker but you sacrifice a tad bit in pad thickness.
However, with regards to the PFC vs. AP debate, I felt the AP discs handled heat better from the design which helps force more air through the internal veins. Also, I noticed more pad knock-back from the PFC floating design, which seems to let the discs float a bit more freely, compared to setups which use mounting hardware to the actual disc, not around it.
All small little variations, but noticeable.
Basic Sponsor
[QUOTE=KA MOTORSPORT;12632066]The PFC 32 mm disc is thinner to allow for a thicker 19 mm pad. The 34 mm disc gets more life due it being thicker but you sacrifice a tad bit in pad thickness.
The PFC 32 MM disc is the real deal race setup allowing not just more pad but less weight. That said, I recommend the 34MM thickness unless you are seriously racing. Always less expensive to replace pads as compared to rotors.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
Former Vendor
In my experience, at least for a stock cayman brake package, there is never too much cooling, especially for the front rotors.
Both AP and PFC discs have similar vane designs if you look at the discs (vane count, type). The difference is in the quality of the iron and materials used. Here I think Brembo and AP are the leaders in disc production.
Knockback is a result of deflection in the hub or upright and while symptoms are in the brakes, is not brake related persay.
Good brakes is all about getting the basics right, not just throwing the most "trick" parts at it.
