Is techron safe for Porsche?
I have used techron fuel additive every so often for years and it has always worked great. In my C5 Vette it would actually fix my fuel gauge by cleaning the sensor. If I didn't use it the gauge would drop to empty every once in a while. Since then I have used it in all my cars every 6 month or so.
What are your thoughts on using this with the Porsche GT3 fuel system?
Received 5,404 Likes
I use before every oil change.
Just curious... why before an oil change? Just a routine thing? Or is there some technical reason?
I also was told to add to a tank of gas, run through the tank, and then dump the oil. I am surmising deposits and ?? must end up in the oil after the solution has cleaned the injectors, etc. I do it every three thousand miles with the oil & filter change. So far, no problems whatsoever with the car, so I will keep repeating this routine.
Agent Orange
Not only is it safe, there was a TSB recommending it - Fill up tank w. fuel, add a bottle of Techron, run until fuel tank half full, then fill up again w. fuel. And yes, I generally try to run it before oil changes.
I have been using it for nearly 20 years in my 911's. My 911SC ran much better when used regularly. The dealer recommended it be used at least annually to clean the injectors. I still use it before each oil change in my GT3.
PS. The TSB I have is number 8510 dated Dec. 6, 1985
I use chevron gas in all my cars and use techron additive every now and again. Just put a bottle in the antique.
http://www.porsche.com/china/en/acce.../fueladditive/
Fuel additive for unmistakable driving characteristics.
Besides following the recommended Porsche maintenance intervals it is important to use the Porsche approved fuel supplement - Keropur. Because poor fuel quality may result in deposits forming on the inner surfaces of the engine and the fuel system, which could lead to the following:
Reduced performance
Increase of fuel consumption
Engine failure and/or reduced engine life
Due to these factors and in order to protect the vehicle’s engine, the Porsche approved fuel additive Keropur has been introduced and can be used for all Porsche models.
The regular usage of Keropur helps to:
stop the build up of carbon on spark plug electrode, which can cause misfires.
prevent carbon build up in the chamber, which can increase compression temperature causing pre-ignition of air fuel mix.
prevent build up of deposits on top of valve optimising air fuel mixture.
prevent deposit build up at injector nozzle which helps fuel flow.
The effectiveness of Keropur depends on its continuous utilisation. Accordingly every time refuelling the vehicle one can of Keropur needs to be added. Preferably for reasons of blending the additive should be added before refuelling.
You can purchase Keropur from all authorised Porsche Centres. For more information about Keropur please contact your local Porsche Centre, they will be more than happy to assist you. You may also refer to your Guarantee & Maintenance booklet.
The video above shows you the working process of the combustion chamber and the relevant parts of your engine, such as spark plug, valve, piston and injector nozzle, which are protected by the use of fuel additive.
Reduced performance
I've been reading about how Chevron/Exon/Mobil (Standard Oil) developed gasoline additives in the '20s/30's, and even the synthetic gasoline made from coal, sold and shared the technology developments with the Germans under agreements, before and during WWII. Tetraethyl lead anti-knock technology for airplane and wartime gas engines, etc.
So I would imagine that modern day additives aren't snake oil either, and pump gas already has quite a bit of what's needed-
Liqui Moly also makes additives-
