ABS pump cycle
ABS pump cycle on my 2010 GT3 with the porsche diagnostics tool did not work. Timed out.
Is the pump faulty? Can you manually bleed it?
Sounds like you're describing a timeout in "workshop mode". Is there a fault code when you run a full vehicle report?
Yes - Tech said it just timed out. Don't think they pulled a full report.
They raised a ticket with Porsche Technical. Let's see. Can't be software. Looks like a faulty ABS pump to me.
