2010 GT3 Radio Removal
Hi
Just bought the radio delete shelf/compartment from Suncoast.
Does anyone has instructions on how to remove the radio unit?
Thanks in advance.
Thanks in advance.
do you need step by step, or generic?
basically, once you get the center console trim that holds it in you use an allen to unlock the radio. the allen depresses a tap on the radio, then you pull it out pretty simple
GT3 player par excellence
^ lmao. u and i get along just fine. i use that tool a lot.
Thanks for everyone's help
One note: Radio has to be switched off by Porsche dealer in programming.
Thanks to Gunter @ Porsche Fremont-Its perfect !!
You don't have to turn it off you just get error codes in piwis but nothing shows on car or normally. But yes you "should" deactivate it.
