Clutch Issue - Any thoughts to cause
#33
Its when I come in hot, but will still be in this condition after car has sat for a couple hours and cooled down.
Clutch fluid is Endless and it was bled when I had the release bearing and guide tube replaced. Action on the slave cylinder was checked and it is fine. I bleed the clutch every tranny fluid change (6-8 track days).
I will have it checked again, however.
#34
Spyerx, i had a similar issue. From time to time car would get stuck in gear after parking. engine off then on and it would release. No other symptoms (grindning, slipping etc).
At first Porsche Zentrum changed shifter cables - no change. Then after some push they agreed to replace complete clutch with pressure plate and flywheel, under warranty. Since then it's perfect, also the clutch feels lighter.
Hope it helps.
Hope it helps.
#35
#36
Dumb question. What would get hot enough to cause the clutch fluid to boil? That doesn't sound right. I have about 30 hard track days on my 4.0 clutch without any issues whatsoever. I am using the 4.0 parts except I have the Sachs Motorsport 764 890NM pressure plate which is the strongest plate Sachs makes. I also have the Cup shifter and cables. Last time my clutch was bled was 4 years ago. I inspected the clutch a few months ago when my engine was out for a rebuild all the clutch components looked brand new. You must have had a defective part. My shop recently had a couple of brand new Sachs pressure plates and they were warped right out of the box. It happens..
#37
Hope it helps.
Hope it helps.
Anyway, it's not silly $ to drop the tranny and replace the PP.
#39
Well one new clutch later and all is sorted for me and the new clutch feels a tad lighter.
Fitted this bad boy which is simply awesome apart from reverse gear HTF do you engage reverse ?
It is nigh on impossible, my technique seems to be (righthand drive remember) hold collar up with left hand and violently shove lever to the left and up it usually goes in after the third attempt but a bit of a PIA for a DD
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
![Name: FullSizeRender%203_zpsqbjfr2hy.jpg
Size: 214.3 KB](https://rennlist.com/forums/attachments/997-gt2-gt3-forum/1232100d1501528286-clutch-issue-any-thoughts-to-cause-fullsizerender-203_zpsqbjfr2hy.jpg)
#41
Since I hate when people post issues and don't follow up... I'm finally following up.
Shop replaced all clutch components (EVERYTHING) and shift action was a mess. Ended up being a bad, brand new factory pressure plate. All new everything again and clutch action if perfect. Ran car on track for 3 hours this weekend in 100+ weather and not one single issue shifting.
My suggestion on these cars is if you're getting funky shift action, just replace EVERYTHING or you'll probably be dropping the tranny again.
#42
Me thinks Porsche has moved on and doesn't care much about making this system work better or policing the supplier.
#43
FK.
So my shop does a lot of big horsepower turbo cars - they use the 4.0 setup in the NA cars, but have been using a few different setups for the turbos.
If this one goes to crap soon - I may give one of those a try. Knock on wood so far so good, the track I was on doesn't have near the shifting of cota, mostly 2-3-4 and mostly 3rd... but it was very hot and I was being pretty aggressive with it.
You want me to find out what they're using?
#44
FK.
#45
Do you know which TexasRS tried?
