How to remove frunk carpet?
GT3 player par excellence
if you want to preserve it. then i dont know
if you just want to pull it and reduce wt. just pull REALLY HARD. that's how i did my stripper.
The Rebel
The proper way of doing this, without being a butcher, is to remove the plastic surrounding the frunk, you also have to remove the rubber stripping. Once you've done that, take the tool box out along with the fixaflat canister. Now look for the screws (3 on the top one by the light and one behind the compartment door on your left) that hold all the plastic pieces...slowly but surely you'll get it done.
Good luck and PM if you have any questions.
Thank you MJ.
There can be only one. Quick or Non-destructive. Patience or Mooty.
