Searching for a 4.0 RS
#33
GT3 player par excellence
congrats Peter
I knew u were a quick mover
#34
#36
Has this 4.0 had the Resonance Tube fix, and/ or the coolant fittings welded or tapped? These are 2 of the campaign Porsche has suggested. I'm wondering how easy it'd be to have the coolant fix done while the getting the Resonance tube fix since the engine is already dropped. Has anyone else done this and/or used the SharkWerks coolant fittings?? Thanks for any information.
Mooty, any wisdom that can be bestowed?
#37
flap is a TSB
polar send the vin to any dealer they will tell u if it's done
it's free and u MUST do it. or u will be very very sorry. pm me
u MUST do it
there's also an
oil galley TSB free ask dealer via ur vin. again MUST do
it
coolant pin and weld is ignored by Porsche as non existent. it's up to u. not cheap to do $4-5000 on average calif pricing. I did mine and God forvit nokng all
oem. my 4.0
is now $100,000 lol
u MUST do it
there's also an
it
oem. my 4.0
is now $100,000 lol
#38
flap is a TSB polar send the vin to any dealer they will tell u if it's done it's free and u MUST do it. or u will be very very sorry. pm me u MUST do it there's also an oil galley TSB free ask dealer via ur vin. again MUST do it coolant pin and weld is ignored by Porsche as non existent. it's up to u. not cheap to do $4-5000 on average calif pricing. I did mine and God forvit nokng all oem. my 4.0 is now $100,000 lol
#39
My seal had been done but not the resonance tube. I AM going to do that and understand it's covered by Porsche. As far as the coolant fix, I'm still a bit confused. Would you sugg using a sharkwerks part or something else in place of OEM plastic fittings and risking disaster. Again, thank you for advice. Seems it would make sense to do that at same time as resonance tube since engine is already dropped. Still several grand if engine is already pulled? I know I just need to ask them but it's hard to trust anyone but a fellow 4.0'er
#41
polar u are golden then
991gt3, u don't drop engine to do resonance tube.
if u do decline pin weld, I would use those two tubes from Alex in place of OEM. those are separate issues from the coolant pin welds.
u should talk to ur mechanic this is not something u chat
over Internet.
over Internet.
#43
polar u are golden then 991gt3, u don't drop engine to do resonance tube. if u do decline pin weld, I would use those two tubes from Alex in place of OEM. those are separate issues from the coolant pin welds. u should talk to ur mechanic this is not something u chat over Internet.
#45
all dealers should know the two TSB mentioned above. if they dont know it by heart, u need a new dealer.
pinning and welding are ignored and not advised by dealer. it's your call.
