Bolt-on Roll Bar reccomendations???
Great thread, and great timing since I was planning on doing a cage for spring.
I have a 2010 GT3.
The OEM Clubsport bar will not allow the seat to go all the way back correct, I can't give up any leg room? I have the GT2 seats.
I have a 2010 GT3.
I am 6'3" using recaro profi xl on sliders with no issue
I have a set of GT2 seats in Suncoast boxes, New in box black GT3 Schroth harnesses, Black OEM clubsport roll bar and factory roll bar mounting plates. $10K u.s takes the combo. (Located in the canada.)
I also have GT2 buckets in my .1GT3RS and would sell/trade them for CGT buckets. (Car/seats are located in Florida.)
I have another P-car in the works and will be perfect for show n tell on my 10000 post
I had a RSS roll bar and Schroth 6 point harnesses installed. The RSS, GMG and the rest that I looked at that are made along the same lines are manufactured out of fairly light tubing. Most the hard core racers call them track jewelry. I installed it because I think it looks good and I wanted it to look like the European club sport package. It would offer some support in a rollover as the roof would have to compress as well as the roll bar, plus it gives you someplace to attach your six point.
GT3 player par excellence
a lot of talk woth no *****.
if u want some protection, gmg, RSS, heigo, tequipment take ur pick
if u want real bars, club sort and TC design
cough up the real money and let ppl cut ur carpet and weld to the tub.
I keep hearing hsi I wamt it orig, no cut no word oh, I wamt it be strong too.....
well I also wish for racing RSR at lemans next year with pat long for $500 bucks
So Im 6'1, and in my GT3 I have the GT2 seats. For my seating position I need the seat to go all the way back, I can't give up any leg room.
I have narrowed my choices down to the GMG RSR, LMS, or RSS 930 cages. Is one better then the other and if so, for what reason? Leaning towards the GMG ones, the diff between those is the extra cross bracing it seems.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
However it will slightly touch the side of the seat when all the way back.
you can do it or you can do it right.
as you know trackcar is really tall and his gt2 seats go all he way back no touching. roll bar installation is not easy. some just bolt them in meh. if you are good fabricator you can make a giraffe fit. tilt the bar. if your shop can't figure it out, find a new shop.
