New Convert: loving my new side muffler bypass pipes (long review)
#32
Grizfish heard mine today. I think he approved of the sound :-)
#33
So, by way of an update, I liked the sound so much I decided to get my own stock center section and return my buddy's to him. His was the titanium version and the one I sourced from a member was steel. I can say that there is less drone and less volume with the steel unit, so if you are sensitive to drone and/or want to minimize it, I would opt for steel over titanium (I must admit it was painful putting the heavier unit on the car...probably at least a 10 pound difference!). Plus, word on the street is that the steel is less prone to cracking when installed in conjunction with side bypass pipes.
Just can't beat a 40 pound weight reduction from the rear of the car!
#34
thanks for the review Scott! I've been contemplating the side muffler delete for some time. the weight and heat you removed is a large factor.
Question: has anybody run the fabspeed rear mini muffler set with side delete? i have the fabspeed set up now and was thinking of doing the side delete but wanted to know if anybody has any experience with that particular set up. I never drive without the sport button but your comment on the stuck valve makes me want to check my car.
#35
Oh wow!
Did the Fabspeed side muffler delete in July and was now just able to put on the Fab speed mini center muffler! Sounds great!!! A tad louder, not too much... Just went for a quick spin. Will take her to the office tomm and report back.
#36
I've run the side delete pipes with the OEM center exhaust and the fabspeed maxflo (2-in-1 side delete pipes that go a small resonator/muffler on each side then out to larger tips). The fabspeed is definitely a little bit louder.
#37
I just had the side delete installed and as some have pointed out, it is pretty loud - good, but much louder than I expected. I'm thinking that on track and with a helmet on it I'll be fine for me, but hope it isn't too obnoxious for others. I know I don't like it when cars are so loud it pierces my ears or makes it so I can't hear my own car.
Between losing the side mufflers, the dual mass flywheel and dynamic engine mounts, I figure I've dropped at least 60 pounds off the back of the car! :-)
#38
See you on track.
#39
