997 GT2/GT3 Forum 2005-2012
GMG GT bar bolt size
Old 07-28-2014, 02:38 AM
audipwr1
audipwr1's Avatar
It appears to be a 9mm hex to drive the bolts is that correct? Who the heck uses 9mm? I have literally every single size but that. Also I had to remove the plastic boxes that sit behind the seats against the b pillar to get it in - that normal? What a nightmare installation and its only just pinned in with metal studs to get it in straight need the right hex socket to install it
Old 07-28-2014, 12:38 PM
audipwr1
audipwr1's Avatar
Any help here? Need to buy hex tool
Old 07-28-2014, 12:54 PM
NorthVan
NorthVan's Avatar
I would suggest contacting GMG
As for removing a plastic box, that sounds familiar, as to when I had a bar put in my 06 C2S. My GT3 came with the Clubsport installed already.
Old 07-28-2014, 01:09 PM
tgavem
tgavem's Avatar
There are many threads on the installation in this forum and in the 996GT3 forum
Not sure about the 9mm hex you are talking about, but yes - the box by the B pillar have to be removed or crushed.
Also, if you use all-thread stud and nut for the anchor near the B pillar instead of bolt, the installation if much easier.
Again, do some research on this as well in the 996 GT3 forum.
Old 07-29-2014, 04:04 AM
audipwr1
audipwr1's Avatar
3/8 standard hex drive is the answer for future searchers
Careful not to cross thread and must remove rear view mirror
Old 08-02-2014, 10:48 PM
F1CrazyDriver
F1CrazyDriver's Avatar
Matt,
Doing this helps, makes process so much easier to line up holes.
Old 08-03-2014, 04:10 AM
Alan C.
Alan C.'s Avatar
Received 1,046 Likes on 538 Posts
I did the same with mine and it was much easier getting the bar in with the straps.
Old 08-03-2014, 08:33 AM
mepps
mepps's Avatar
great idea on the straps....that would have made it much easier!
Old 08-03-2014, 11:13 AM
audipwr1
audipwr1's Avatar
Yeah that's smart what a pain that job was
I did listen to you and remove rear view mirror
That was smart
Old 10-05-2014, 09:06 PM
MK_TT
MK_TT's Avatar
Did you strap the bar before or after you put in the car?
Originally Posted by F1CrazyDriver
Matt,
Old 10-05-2014, 09:17 PM
Rolltide86
Rolltide86's Avatar
Matt,
That just seems wrong in so many ways - is the GMG fit so bad that you have to do this???
Old 10-05-2014, 09:27 PM
audipwr1
audipwr1's Avatar
I had to squat the bar in while wife drove bolt in - least favorite car experience of all time
Old 10-05-2014, 09:32 PM
Alan C.
Alan C.'s Avatar
The GMG fit is outstanding. The problem is the plastic part surrounding the area where the lower bolt goes into the car. The plastic can be compressed by the bar as it is tightened by the bolts but it is a major pain. The strap pulls the bar in and allows the bolts to be started easier. It also helps to prevent stripped threads if the alignment is off. The other way is to pull back the carpet and cut the plastic around the bolt holes.
Caution! It takes very little in the way of force for the bar to crack the windshield. When I removed my bar from a C2S it bumped the windshield and it cracked. Couldn't believe it.
Old 10-05-2014, 09:41 PM
audipwr1
audipwr1's Avatar
Maybe if u remove plastic part it's easier
I didn't remove and it was a miserable experience
Old 10-05-2014, 10:22 PM
Alan C.
Alan C.'s Avatar
In comparison cut the plastic and you will think you died and went to heaven. I've done it both ways.
Quick Reply: GMG GT bar bolt size
