Advice: Replacing my PCCB pads-Do I need new dampeners?
Car is 100% street driven.
Are the dampeners stuck on to the brake pads with an adhesive? Can they be reused?
This is what I'm going to be ordering unless you tell guys tell me something is redundant or I missed something.
1.Front brake pads (OEM)
2.Rear brake pads (OEM)
3.Front caliper repair kit (replacement springs, retaining pins, and spring cotter pins)
4.Rear caliper repair kit (replacement springs, retaining pins, and spring cotter pins)
5.Rear caliper bolts (4 total)
6.Front brake pad dampening set (should have 12 in the kit)
7.Rear brake pad dampening set (should have 8 in the kit)
TIA
TIA
I am on my 3rd set of pad and I have never refreshed any OE parts. Not sure why u need to refresh so many parts if there is no damage?
I have been tracking hard but I am not a heavy brake person.
TIA
TIA
Just figured new components would guarantee me everything running at 100% and as mentioned wasn't sure if the dampeners could be reused.
I will only order the caliper bolts for the rear since the front pads can be changed without removing the caliper.
caliper bolts are not reusable according to factory procedures, there are multiple threads on this topic elsewhere in the forum.
imagine the looks from other drivers as you pull up next to them at the lights or stopsign ... and they look over expecting to see an 18 wheeler or a bus and instead they see you in your 911
you have been warned!
One of the reasons why I'm changing the pads is that I'm at about 6-7mm of pad thickness which is about 50%. Many have recommended changing the pads at 50% to ensure rotor life. They are also worn at an angle. The other reason is that they are very noisy and I can only get them quiet after I rinse them with the garden hose but that only works for about 30miles. I did 3 hard brakes from about 120mph and that didn't help.
How would you go about removing the glaze (assuming there is) on the rotors?
http://www.stoptech.com/technical-su...nd-other-myths
and...
http://www.stoptech.com/technical-su...and-procedures
not too mention...
http://www.stoptech.com/technical-su...eposit-removal
hope these help!
I have been using the pads down to 20% front and rear. No issue. I never run pad sensor in order to run down the pads that low.
Ppl change it at 50% as a safe guard in case of the owner never watch out the taper pad issue. For the front pad, I rotate it after 5track days and the taper issue is not too bad. For the rear, no taper, just higher wear that the front pad.
I have never change caliper bolts and not sure why I cannot reuse it. With 50ftlb, I do not think I am stretching the bolt. I want someone to answer this too.
Isn't the torque 63ftlb?
Are you using the stock pads? How noisy are they? How are your rotors holding up?
Either replace the caliper bolts or get the motorsport studs. I never replaced the caliper bolts on my brembo caliper on my M3, but I tracked more often and would swap between track and street pads and retorque the bolts very often, so didn't really worry about the bolt getting loose. But I ran same set of pads on RS (OEM on PCCB, then PFC08 on steel rotors) for track and street. Plus CL is a hassle. So I got the studs, knowing I'll rarely remove the wheels to check the bolts.
It's a personal preference, but I also replaced the pad sensors because they were old and brittle. Or just remove them completely.
