997.2 brake feel
997.2 brake feel
The brake feel on my mk2 GT3 seem like it has a lot of pedal travel before the brakes actually "feel " like they are working. Yes I have pfc08 pads with Pfc rotors...so I know heat needs to be there. However my street (stock) 997.1 C2S feels amazing...at the top of the petal. My 996 GT3 also felt great at the top. To the point that you can literally use your big toe to apply normal braking.
Braking is there and insane on track. But the extra pedal travel never goes away. The 997.2 has had new pistons and seals done. So outside of a new booster...I'm not sure what to look at. Rock hard when car is off...and releases when car starts.
Is this just a trait of the gen2? Any help from a gen2 driver would be appreciated.
make sure the little metal plate on the PFC08's back plate is removed, otherwise, it will cause the pistons to sit slightly back and give a soft pedal.
This can sometimes happen after changing the piston seals if they aren't really well lubricated for reassembly. The pistons flex rather than slide on the seals when you brake, and then the pistons retract when you let off the brake. That's where the pedal travel comes from. If you pump the pedal quickly the pedal gets firmer at the top, and you'll know that this is the issue. Use a lot of brake caliper assembly lube (NAPA) when rebuilding. You should be able to press the pistons back in easily with just your thumbs if the pistons are sufficiently lubricated. Then this problem doesn't occur.
Check the brake pads. My shop left the removable metal plate on the back side of the 08 pads, and that's what caused the soft pedal for the first couple inches, they sometimes bow out from the backing plate, which push your pistons back....I removed it, and presto, back to normal rock,hard GT3 pedal. Check your pads....
I don't have a .2, but my .1 with PFC and brebmo rotors with endless fluid is pretty grabby right at the top of the pedal travel, nice firm feel.
I'm with others here: check for any spacers between pucks and pads (remove them), ensure pistons are all free, lastly it might be worth doing a full purge/flush of your fluid too, possible have some air in there?
So I met with Clark from apex this weekend at the track. He was the one the turned me on to the Pfc pads. We can't figure out which part is supposed to come off? All we could
See is the metal plate...and the carbon brake material?
Sorry for my ignorance...but what am I missing? I
