Where to buy racing helmets for track use?
Addict Rennlist
They should be able to assist you with a helmet.
Bill
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
http://www.helmetcity.com/page/HC/CTGY/AH
I bought my motorcycle helmets from them but I happened to be in Daytona at the time. IME, need to try it on to make sure it fits properly, so I would be a little leery buying online from anyone. Cyclegear has a great selection and there might be a location near you. I forget the difference between car & bike helmets but depending on that answer, you might do well there. Seem to think motorcycle helmets are not fire retardant.
1. Multiple impact rating (SA) for roll bar/cage protection. M has single impact rating.
2. Visor is much tougher at a higher rating for object intrusion/impact and hardware for visor attachment is rated much higher also (usually metal not plastic).
3. Smaller eye port vs M class for more protection. Even the large eye port SA helmets are smaller than most if not all M class helmets. M class full face helmets are cut higher above the brow to compensate for sight line on a sport bike, SA class helmets are cut lower because no such problem exists for automotive applications.
4. Nomex liner (SA).
5. SAH rating is Hans ready/compatible/predrilled/preanchored. Almost all SA helmets come predrilled now, in 2005 it was more rare, in 2000 it was nonexistent. M class obviously has no Hans anchor points.
6. SA class helmets usually preformed foam inside for microphone/communications system. M class, almost never.
