25k mile 2007 .1RS
Water pump? Ummm none. Other than coolant pipes as preventative. This is not high miles. Just get a good ppi. Clutch if it's been beat to hell.
just wear and tear kind stuff. Calliper dust boots. Calliper bolts.
Rear main seal might be a little dried out and leaky but no real cuase for concern.
25k miles is nothing on these cars.
GT3 player par excellence
u mean water/coolant hoses?
i am not aware water pump issues. but it should be replaced whenever the engine is out. cheap part $$$ labor
All correct. I have 27K on mine, car has been bullet proof. In my 3 years of ownership, and beating the hell out of it on track, I have not had to replace anything due to mechanical failure. Recently performed the following maintenance in the last couple thousand miles:
Rear main seal (mine was an early build, didn't even have the TSB "spacer" Porsche added to the RMS)
New Clutch & Fork (it was actually working fine, but free labor at that point)
Pinned all coolant lines
Spark Plugs
New Caliper dust boots
Spark Plugs
Thanks all.
The reason I asked about the water pump was that, although the GT3 is a very different car, my 2006 Carrera S gave up hers at 26k, and I've heard of many others having to replace also around that mileage.
I appreciate the feedback.
Vivian.
Vivian.
Spark Plugs
Spark Plugs
the car I'm looking at was first sold April 2nd 2007. Is your car similar vintage?
Dealer tells me clutch, belts, plugs and ignition coils done.
Vivian.
