Manthey's 4.4l Mezger for GT3 announced
#46
You make good points, the NA powerband will be easier to maximize from a driving standpoint.
But the TORQUE! The GT2 will still have a massive torque advantage. I think on a tight twisty track, the NA 530 hp will win. And a track with long straights, the GT2 should win. Will be close either way though.
Torque has its biggest benefits when you are in the wrong gear (too tall) or the gearbox has widely spaced ratios, or from a standing start. If you keep the GT3 on boil, there is no meaningful deficit from the lower torque.
#47
9400rpm - is that right, seems very high ![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Not wanting to put any negative slants on the US offerings (I like Sharky
) but it is worth pointing out the development which Manthey and RS Tuning put into their engines before releasing them for street use. Lots of racing and engine dyno time, strip downs measurements etc etc. The RS Tuning 4.5l has a 6 month schedule.
As for how fast these are I was told the RS Tuning 4.3 GT3 street conversion which is 534PS @8400rpm and 517NM @ 5300rpm was "as fast" as a GT2 RS when track testing in Europe.....
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#49
#50
The torque of the GT2 is not that big an advantage when the GT3 has a 9k redline and 7 closely spaced performance gears. Particularly on a long straight - more about power.
#51
I've been spending a bunch of time in the 991 GT3 forum and forgot where I was when I mentioned 9k redline and 7spd close-ratio. With the PDK (I personally prefer manual), the time wasted shifting that you mentioned is a non-issue. A well driven 991 GT3 will never miss the torque of a turbo motor in the way that the driver of an older GT3 might (easy and fast to always be in the fat part of the power curve).
#52
Yes, torque is a big deal if you are not diligent about being in the proper gear.
When it comes to manuals, you cannot always be in the proper gear. Sometimes a higher gear is faster, sometimes a lower gear is faster. When choosing a higher gear, torque is always useful. It makes gear selection much easier.
The grip level of the tires is important, torque is useless if it overpowers the grip. I think it would depend on what tires were on the car.
#53
Surprisingly the 4.1 has a stock 997 GT2 covered for torque to the wheels, and it's got a wider power band. Top speed in gears 2-4 is similar, and the shorter gearing allows the 4.1 to be equal to or ahead of the GT2 on thrust to the ground everywhere. It really is turbo grunt with normally aspirated response. Devastating combo. I can only imagine the 4.4 will be even more so.
#54
Had a few GT2s here lately and yes they'd be a nice happy meal for our car. A GT2RS and then some tuning, cats and
[/QUOTE]
Perhaps if you tested a GT2 from Florida with a Werks1 badge, Happy becomes UnHappy very quickly.
#60
