997 GT2/GT3 Forum 2005-2012
How many quarts of oil required for an oil change?
Old 12-10-2013 | 10:07 PM
ILLCOMM's Avatar
ILLCOMM
Default How many quarts of oil required for an oil change?
Also, can anyone confirm Motul 8100 X-cess 5W-40 is Porsche approved? I believe it is.
Motul 007250 8100 X-cess 5W-40 Synthetic Gasoline and Diesel Engine Oil - 5 Liter Jug : Amazon.com : Automotive Motul 007250 8100 X-cess 5W-40 Synthetic Gasoline and Diesel Engine Oil - 5 Liter Jug : Amazon.com : Automotive
Old 12-10-2013 | 10:09 PM
911rox's Avatar
911rox
About 8.5 litres on a 997.2 GT3 so whatever that is in quarts
LexVan's Avatar
LexVan
Yes, Porsche approved. About 8.5 quarts??
Old 12-10-2013 | 10:12 PM
ILLCOMM's Avatar
ILLCOMM
Thanks. Looks like that's just under 9 quarts.
Old 12-10-2013 | 10:17 PM
ILLCOMM's Avatar
ILLCOMM
Posting this list of approved oils for future readers: http://www.pedrosgarage.com/Site_3/P...oved_Oils.html
Old 12-11-2013 | 01:01 AM
JB911's Avatar
JB911
It's 9.5 quarts if you change the filter and let it drain completely-unless you're not talking about a 997.2 GT3, not sure about the others
Old 12-11-2013 | 01:02 AM
ILLCOMM's Avatar
ILLCOMM
I have a 7.1 GT2. I am assuming a similar amount to a GT3.
Old 12-11-2013 | 01:14 AM
JB911's Avatar
JB911
It could be that the GT2 takes less oil than the GT3, maybe it's the same as the Turbo, and owner could post here to clarify.
An accurate reading on the GT3 is with a hot engine, above 200 degrees. After change, cold/warm reading usually shows under. If one panics and adds more oil during a warm reading, once it reaches hot temp you end up finding out it's too much oil. It might be similar with the GT2 and Turbo, and maybe it's 8.5 instead of 9.5 in your case-
I've been using the Mobil 5W-50 since it's hot in FL
Careful draining, it comes down fast!
Old 12-11-2013 | 01:53 AM
sharkster's Avatar
sharkster
Yep exactly. And when you take out your filters inspect them for metal shavings and what not. You can nip things in the bud before they get bad that way....
Old 12-11-2013 | 02:23 AM
Spyerx's Avatar
Spyerx
Just did my .1RS and it was 9L (9.5qt) exactly to get the level meter to the full bar when the car was hot. Started at 8.5L(9Qt) and it needed another 1/2 qt once hot.
Old 12-11-2013 | 07:47 AM
brake dust's Avatar
brake dust
What if your tracking your GT3? Some suggest to slightly under fill - thoughts?
Quick Reply: How many quarts of oil required for an oil change?
