FS: 997.1 GT3 steel front and rear rotors (PCCB conversion)
I have the complete front and rear rotors needed to convert a .1 GT3 from PCCB's to steel rotors. The front rotors are the expensive cup car versions. The rears are the solid rotors from a 997 Turbo. I have used these for 2 track weekends.
New, the front rotors are $1,000 each. ($2,000 total)
News, the rear rotors are approximately $180 each ($360 total)
The rotors all measure the new thickness (32mm on the fronts, 28mm on the rear). There is some minor cracking around a few of the drilled holes. However, this is completely normal and evident after the first day of track use.
Put your PCCB's on the shelf and use these for the track. These work perfect on a .1; however, I think that the lug bolt holes on the front are too small for a centerlock .2 car.
$850 via paypal
$800 if you send me a check or wire. I will even give you an overnight label to send it to me. I will then ship the next day.
Thanks!
$850 via paypal
Thanks!
