Water pump differences
Replacing water pump on the GT3 after one of the coolant hoses popped last week.
Noted a distinctly different pulley vs. the "normal" M96_97 water pump. The castings carry the same number and the impellers are shaped identically, so was wondering what the real difference are between the two pumps.
Even though the pictures are deceiving, the pulley on the "regular" one is about 10mm larger in diameter than the Mezger one. All else being equal, the regular one would spin slower, pumping slower than the Mezger one.
Were one to consider swapping one out for the other, your sepentine belt will be too tight / loose.
Off topic: I'm trying to reply to your PM and Rennlist is telling me that you cannot get PM or have elected to have them turned off? Shoot me another PM with your e-mail and I"ll send you the info you were looking for.
