Street brake pads for GT3 RS
Looking to swap out (and sell) the PFC08 front and rear pads on my RS street pads.
Ideally something like Centric Semi Metallic would be perfect. I am just confused as to what the correct pad is for the front PCCB caliper with PFC 2 piece 380mm floating steel rotors and the rear PCCB caliper with Porsche Turbo steel rotors.
I believe the front part number is 104.09910 (104.14310 is also an option but I think it is too thick?) but I can't tell if the correct rear is 104.13000 or 117.37009
If anyone knows the correct dimensions or part numbers so I don't have to remove my pads to measure them it would be most helpful! Thanks.
Jenner - Eddie hooked me up with OEM street pads for my .1 RS with PCCB but I have cup steel 380mm front (32mm thick vs. 34mm thick) and .2 RS steel rears on the car right now. He was also able to give me the PFC part numbers for the cup rotors (32mm thick) and for the PFC rotors with same setup, they are different. For the OEM Pads, he got me the .2 OEM street pad part numbers which fit fine with my setup (.1RS, PCCB, cup fronts .2 rotors, rear .2 OEM rotors). Let me know if you want me to grab the part numbers off the boxes.
Thanks Spyerx. Part numbers don't really help unless there is a way to get the dimensions from them. OEM pads are like $600 for the set, Centric are 1/3 the cost...
Maybe this helps, this is the dimensions of the Pagids that I pulled from the car and swapped with the OEM.
Measuring with a ruler here so don't claim 100% accuracy:
Front: 190 x 101 x ~16mm thick. Some wear on them
Rear: 130.5 x 75.5 x ~13.5mm thick. Some wear on them
One note, Eddie mentioned to me the pad PROFILE area is slighty different with PFC rotors. Not sure if it's to clear the hat area or what. But that could be an issue with OEM / aftermarket pads with PFC rotors.
Basic Sponsor
Guys you both have the same hats/rotors. If it works on one car it will work on both.
997.1 with PCCB originally and 997.2 are the same PFC part numbers on the rotors
0378.32.0060.45/.46 not 380. Cup car and RS rotors are the same....the hats are the only thing that are different.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
Spyerx thanks so much! That confirms the sizes, now just the thickness is questionable.
"Then there are the slotted rotors with a swept depth of 60mm that require a narrow pfc pad and I believe will accept the narrower pagid pads althought you'd need to confirm this."
