PCCB pad change question
I'm changing front brake pads for the first time on my .1 GT3 with PCCB.
I have removed the retaining pin and it looks like some sort of loc tite was used previously. Do I have to do that when I reinstall? See photo below.
I'm about to install the new pad and I see that I have to remove some blue paper. Under that is a thin sticky metal plate. I assume I leave that attached to the pad as it's probably some sort of anti-squeal shim. Am I correct? See below.
Thanks for your expertise.
Gotta love the internet.
That's a pad retaining pin. Not a caliper bolt.
If you throw away the plates let me know how the squealing is. I left mine out on the back and it seems like the squealing got 3x worse.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
torque to 24 ft-lbs, the spring keeps that pin in place even without the bolt.
Do not use loctite in that pin, not needed.
The aluminum isolator reduces noise on street use.
For track-only use, ignore the spring (reduces temperature on brakes, and a little faster pedal reaction), torque the pin higher (Clarke, 62 ft-lbs is way too much for a 13mm bolt, that's torque for the caliper bolts for the uprights, no need to remove caliper in the front for pad changes), and use a titanium back plate isolator to reduce temperature to the pistons.
