2011 rs cam actuator - warning signs
Intake recall work completed yesterday, on the drive back from the dealer heard a suspicious noise from the right side of the engine, wondering if it might be the cam actuator. No change in engine performance. For those that experienced this problem, what, if any, were the warning signs prior to engine damage, and how much time (mileage) passed from first symptom to end result? Car is back in the shop now - open to ideas & suggestions how best to proactively fix this before something breaks. Many thanks!
If/when the actuator fails its screws will grind against the cam cover. Often it's the right hand side (looking from back of car facing front) intake actuator (i.e. top one) that goes first. Telltale sign will be circular scratch marks on the inside of said cover. But that bit may not be accessible without dropping engine...
Part 14 of the following (understand there's a left-right flip but you get the idea), courtesy of AutoAtlanta:
![](http://c782433.r33.cf2.rackcdn.com/103-10.gif)
Thank you CRex. Is it safe to assume once the screws have backed out, there is no mistaking the nature of the problem? I've heard the sound twice in 40 miles. Took the tech for a 10 mile test drive and could not replicate it. Appreciate the diagram.
Yes, it'll be self evident. The more they grind the more fine metal particulates are released into the oil circulation. And with that, horror...
One last clarifying question to help troubleshoot the issue. With this type of component failure, is it possible for the symptom (in my case, a loud ticking/clacking noise on deceleration) to sporadically appear? It would seem that once the screws back out - the problem is unmistakable. Thanks again for your insight!
Ok, so what the heck is going on here? Is this another .2 GT3 issue?
Friend with a 11 RS brings car to dealership for intake recall. The next week, at the Glen, car shuts down with lots of noise (no warning I think). Even the engine lid "locked" itself at some point, with no way to open it up.
Towed to dealership, and this is what they found:
Wow, BOTH actuators popping out eh. That's worse that most I've seen. Any reason to suspect engine abuse? (not that it's needed--these things often come out on their own but PAG insists that overrevs are the "main" culprit)
I still believe this is part of the low speed harmonic that PMNA acknowledged for cars with lightweight flywheels (all RS's). We'll find out with my 4.2 and the harmonic balancer we're installing on it!
I had the left bank exhaust actuator go when the car was approx. 8 months old
3 others in Australia at the time that I am aware of 1 was an RS. Mine was the first
The telltales for mine was a slight rattle on startup twice over approx. 5 days. The first I wasn't sure I actually heard anything.,
The second happened upon starting to go out for some warm up laps - Porsche techs were at the track and heard it and came over.
upon shut down there was another rattle and the check engine light came on
Car put on flat bed to Porsche and much deliberation between Porsche Oz and Germany while they sorted what the problem was and what the solution would be.
Since then no issue - I believe the screw sizes and/or torque settings were changed
fwiw, the RS owner had engine grenade on him at track - Porsche replaced the engine under warranty
While my car is in for a grenaded PP and the engine out, I asked PCNA to replace the actuators (which is all they can do, they won't torque the bolts, loctite etc). They are covering replacing all 4. I hope the new ones hold up.
