Broken drop link joint - comments please ?
If you've modified your ride height, then the joints may be binding. Check the angle of the pin when the car is at rest and if its substantially different than 90 degrees, replace with adjustable links.
I'm thinking they failed because your car is squatting so much under hard acceleration. You are making more power than stock, right?
Maybe its worth checking the part (06) from the GT2 RS?
Message Eddie at race parts warehouse, buy cup drop link
Your car must be lowered?
The stock sway bar link suffered multiple binds due to geometry being different than stock.
Install a set of Tarrett or compareable drop links. They are adjustable to dial in the desired length and are very strong.
Easy fix and much needed in your case.
The irony of the matter is that it takes so much patience to actually install them properly and eliminate pre-load, that the adjustment is a moot point. Most people who install adjustable droplinks don't eliminate pre-load. Since there is no rubber in the original units, there isn't a more direct connection to gain either.
This is coming from someone who used to assemble and sell adjustable droplinks for 944s, air cooled 911s, e30s, etc.
