FS: 997 GT3 FabSpeed Exhaust
FabSpeed side muffler deletes and max flow mini mufflers with black tips. Check out the retail price and you will know this is a deal. Driven for 4k miles, practically new.
Just traded in my 2007 GT3, so factory exhaust was restored.
$1,200 shipped to 48 states.
Thanks.
Thanks.
I get the rear weight loss w this setup... Which is always desirable.
This or eddie's m&m + elbow setup or shark track pipe... I'm not planning to do any software.. I don't drive on street unless I'm going to a shop or track.
Is there Dyno for fab setup? Eddie's setup is proven. Shark track pipe benefits w software..
I have Sharky Bypass and on track, I want it louder.. I assume as side delete setup, drone, loss of power under 3k exists (non issue for me) - I'll never have car under 3k rpm on track anyways.
Yes, the exhaust is very light. I don't think there is any dyno proof that this puts out more power. If sound is what you are looking for (raw race car sound that draws a lot of attention), then this is perfect. It does drone if you are in 6th and cruising at 3k RPM, but if you are ripping through gears, it is glorious.
Actually we have a GT3 RS in the shop right now that we were making some changes to our header design. In the process we re-dyno'ed all of our components on the car. The mini-maxflos pick up about 20 ft. lbs of torque between 2900-3900 and about 5 hp on the top end.
