Torque spec for centerlock rotor hardware?
My oem rotors are toast so I'm going to install new oem front rotors myself this weekend.
I purchased new hardware for each, so does any one know what torque specs (if any) are specified for the fasteners of the pins under the sleeves as shown below...
![](http://www.suncoastparts.com/mm5/graphics/00000001/CENTERLOCKROTORHARDWARE.jpg)
I think it's the part I bolded near the bottom
Tightening torques for brake mechanism
Technical values
Threaded connection securing brake calliper to front and rear axle, M12 x 1.5 Always replace screws on front and rear axle following removal. Tightening torque 85 Nm (63 ftlb.)
Retaining pin for brake pads for 6-piston brake callipers, M8 Always replace screw following removal. Tightening torque 30 Nm (22 ftlb.)
Brake hose bracket to brake calliper and rear-axle side section (M6) Tightening torque 10 Nm (7.5 ftlb.)
Combination plug connection (plug-in coupling) to wheel carrier (front and rear axle), M6 Tightening torque 10 Nm (7.5 ftlb.)
Threaded connection securing brake disc to wheel hub (front and rear axle), M6 Tightening torque 10 Nm (7.5 ftlb.)
Threaded connection securing brake cover plate to front and rear axle, M6 Tightening torque 10 Nm (7.5 ftlb.)
Threaded connection securing speed sensor to front and rear axle, M6 Tightening torque 10 Nm (7.5 ftlb.)
Threaded connection securing brake unit to body (aluminium interm. part), M8 Tightening torque 23 Nm (17 ftlb.)
Threaded connection securing brake unit support to body, M8 Tightening torque 23 Nm (17 ftlb.)
Threaded connection securing parking brake console to body, M8 Tightening torque 23 Nm (17 ftlb.)
Threaded connection securing bracket for hydraulic unit to body, M6 Tightening torque 4 Nm (3 ftlb.)
Threaded connection securing hydraulic unit to holder, M6 Tightening torque 5.5 Nm (4 ftlb.)
Threaded connection securing wheel to wheel hub, M14 x 1.5 Thinly grease thread, shank and under head (between screw head bearing surface and spherical cap ring) of the wheel bolts with Optimoly TA (aluminium paste). Do not grease bearing surface of the spherical cap facing the wheel. If heavily contaminated, clean the bolts first with a lint-free cloth. Tightening torque 130 Nm (96 ftlb.)
Wheel to wheel hub/central bolt All contact surfaces of the wheel, wheel hub and brake disc as well as the trapezoidal thread in the wheel hub must be free of abrasion, sand, dust or chips. Apply some aluminium paste (Optimoly TA) on the trapezoidal thread of the wheel hub if necessary. Grease the conical surface of the central bolt with a very light coating of aluminium paste (Optimoly TA) before fitting each wheel. For advanced grease specifications (which are only necessary under certain conditions), refer to the description Removing and installing wheel with central bolt. 3-step tightening procedure (Step 1: Tighten to 600 Nm (444 ftlb.). Step 2: Loosen the central bolt again (slightly) by approx. 60 angular degrees (1/6 turn). Step 3: Tighten to 600 Nm (444 ftlb.)). The tightening torque was increased to 600 Nm (444 ftlb.) (previously 500 Nm (370 ftlb.)) in the course of model year 2011. The higher tightening torque also applies to older vehicles. 600 Nm (444 ftlb.)
Brake pedal to brake pushrod (M8 x 1 threaded bolt) Always replace threaded bolt following removal Tightening torque 10 Nm (7.5 ftlb.)
Brake pushrod to brake booster (collar nut M6) Tightening torque 10 Nm (7.5 ftlb.)
Brake pushrod to adjusting piece (lock nut) M12 x 1.5 Tightening torque 30 Nm (22 ftlb.)
Pedal bearing axle in pedal block Tightening torque 8to10 Nm (6 to 7.5 ftlb.)
Locknut pedal bearing axle to pedal block right M8 Tightening torque 10 Nm (7.5 ftlb.)
Locknut pedal bearing axle to pedal block left M14 Tightening torque 46 Nm (34 ftlb.)
Tightening torques for brake pedal/pedal bearing axle
_When replacing brake discs -2- on vehicles with centre-lock wheel, five new wheel attachments -1- must be fitted.
The wheel attachments -1- (5 x), comprising an attachment pin , sleeve - and self-locking screw - , are only available as a set for one brake disc (Part No. 997.341.901.00).
When fitting the wheel attachments -1- , always check the following:
All contact surfaces must be clean and free of grease.
Tightening torque for self-locking screws -1.3- = 6 Nm (4.5 ftlb.).
Technical values
perfect! thanks
