Change in exhaust tone, sluggish performance
As soon as I turned on my car this morning, I noticed something was wrong. The exhaust tone was a lot deeper and more raspy. I have the SW bypass, and have had the car for 8 months now, so I have a pretty good idea of what it should sound like.
Also, on the freeway the car felt sluggish and didn't accelerate like it normally does. I've noticed over the past couple days that the oil measurement tool fluctuates quite a bit. On some occasions it shows above the half way line, on others it flashes below the minimum line, even when at full operating temp.
Everything was running fine last night. On my way home I visited my normal gas station and filled up with 91.
Could bad gas be the is the reason for all these symptoms? My car's ECU been mapped by EVOMS for 91. I'm pretty sure I filled up with 91, but maybe I hit 87 by accident?
My car is at the dealership right now, I've asked them to flush some of the gas out of the tank to take a look. Any other ideas? I'm Pretty worried right now...
Last edited by entityx; 04-04-2013 at 02:51 PM. Reason: Asked for: Any other ideas?
Can be bad gas , maf going afoul, catalytic converter going bad ,exhaust leak ,intake manifold leak, O2 sensors. Had it all cept cat. Hope it's nothing big. Mike
Well, If you hear the exhaust sound different, hard to believe it has anything to do with bad gas... check your exhaust system for leaks, cracks, and also a broken/ clogged catalyst converter.
A bad cat would cause all symptoms you describe.
A
Only thing that was done under warranty was when my intake manifold hose(s) popped due to spinning backwards in gear. Never brought in the car for other stuff because had an indie. Besides when it broke it away post warranty period. Never had cat issues because I was using catbypass. Mike
Thanks for all the feedback guys. The dealer just called and said they couldn't find anything wrong with the car, no fault lights etc. The oil was a little dirty but not anything significant.
I'm a little bit confused at this point. I forgot to mention that I have a PSE carnewal remote installed - i'm wondering if somehow the exhaust valves aren't opening all the way. I don't think this would explain the sluggish acceleration I experienced, though.
How thorough was the dealer with inspection? Was it more than just hooking up to the computer to look for faults? Don't know much about the exhaust flappy thing but does a solenoid open and close it. Maybe it's broken. So it's sluggish from idle on or past 4k rpm? Mike
Also did they pump out the gas for ya if it's 87 or 91 like u mentioned. Why don't u just go to sonoma raceway's finest pump station and put in some high octane fuel and see what happens. There's also gotelli's in San Bruno that sells high octane unleaded gas in 5 gallon containers(it's vp brand). Mike
Would you mind telling me the indy shop you took your car to, just in case?
